Voltage for Receiver Unit
wdwray
Post by wdwray »
The wireless receiver (4 Channel with relays) is rated for 12 volts; what is the range of voltages it will tolerate? I'd like to use one in an application with a 14.4 volt power source.
Re: Voltage for Receiver Unit
Then you should install a voltage regulator say "7812" IC. 14.4V seems too high for the controller.
a-ron
Post by a-ron »
just got my 1527 Tx/Rx Kit (Metal case) today and with no readily available 12v supply decided trying a 9 volt. it worked but now curious about long term effects this might have on the circuit. should I be asking this in a new post? :)
It won't be stable if driven by 9V
