JLD634 Ramp/Soak PID minimum programming interval.
aklz
Post by aklz »
Hi,i´m after to make a toaster reflow soldering .I´d like to use a
JLD634 Ramp/Soak but i want to know what is the minimum programming interval?
Once people use secondes to program ramps etc.
TIA
Re: JLD634 Ramp/Soak PID minimum programming interval.
You can use 'Second" or "Minute" for the interval . The programmer allow you to choose either way
You may get the manual from the download section
aklz
Post by aklz »
Tanx Marco.
