Need a stepper driver suggestion to go with my 2012 DSP
ashkalb
Post by ashkalb »
Hey All -
I have a Buildlog 2.x laser, and am installing a 2012 DSP. I've been having some trouble with the Buildlog 4-axis board as a stepper driver, and I think I'd like to just replace it with some drivers that are not pololu based.
Any suggestions?
Much appreciated.
Re: Need a stepper driver suggestion to go with my 2012 DSP
Post by waltfl »
Hi there
I am using the 2m542 from marco lightobject they work perfect
ashkalb wrote:Hey All -
Any suggestions?
Much appreciated.
twehr
Post by twehr »
waltfl wrote:Hi there
Any suggestions?
Much appreciated.
Yep - that is the one to use.
twosoc
Post by twosoc »
Hmm, I've got these too, what settings do you recommend?
Post by waltfl »
try in lasercad 25.000 for X and Y then make a square of 50mm cut it then measure the real numbers and put them in this should take care.
the driver setting I would start with the setting of 8 on the dipswitches
twosoc wrote:Hmm, I've got these too, what settings do you recommend?
twosoc
Post by twosoc »
cool, cheers, I must have a wire in the wrong position or something as I have it set to those, and it still is like a spider on a hot plate. jittery all over when you try to do a box.
Post by waltfl »
Hi
I just remembered that I had a guy who did use the wrongconnection instead of X-Y he used the U-Z on the dsp
check this.
did you connect the driver like the schedule shows??
twosoc wrote:cool, cheers, I must have a wire in the wrong position or something as I have it set to those, and it still is like a spider on a hot plate. jittery all over when you try to do a box.
geotek
Post by geotek »
Have you tried changing the Pulse Edge on the Manufacture's Settings?
twosoc
Post by twosoc »
no I'm just about to change it for the setting s Walt posted elsewhere. May have messed up the user parameters, anyone got a screenshot of how they should be for the moshi upgrade? Failing that is there a way to reset to default?
Just to double check is the "range" the maximum table size? I.e. 300 x 300.
Cheers, tim.
Users browsing this forum: Google [Bot] and 2 guests
