3 Axes controller board - 6B6560-3V5
alltrades850
Post by alltrades850 »
Wheres the manual for the new 6B6560-3V5 Board ?
Re: 3 Axes controller board - 6B6560-3V5
Thank you for waiting, the manual is available from the "Manual" section. Here is the link:
viewtopic.php?f=16&t=186
austin.mn
Post by austin.mn »
Having a little trouble understanding setting the current and step resolution.
On page 5 of the manual it says
SW1 SW2 Mode SW3 SW3 Resolution
on on 100% on on 1/16
off on 50% off off 1/8
on off 25% off on 1/4
off off 0% on on 1
I am assuming that SW1 refers to D1 on the board SW2 = D2, SW3=M1 the other SW3= M2
On the picture of the driver board in the manual it has a line drawn to the other dip switch (T1 T2) as the current setting switches, but there is no truth table as to what the current settings are. Could you please post the current settings table, and give a brief explanation of the Mode setting.
Thank you
New manual updated, please download it from the Manual section
austin.mn
Post by austin.mn »
Sweet, thank you.
I got my laser up and running this weekend. All went well, for the most part...
Don't forget to share your great job here! Possible send us some picture and the problem you have during setup. That way, it help other folks to learn more! I'm tired and I can't do all alone, need your help :roll:
