Hi all
I was thinking it would be a good idea to open a thread for Tips and tricks where everybody can put his practical tips and tricks in for everybody to profit from it.
also i ask everybody to put his tips and tricks in here instead all over the forum where sometimes can be very time consuming or many threadswith pretty much the same contend.
Tips and Tricks
Re: Tips and Tricks
here my first tip
to hold the cooling water clean I use the water cleaner " algae control" for fish tanks
I boughtit at wall mart.
Re: Tips and Tricks
here are another tip
if I draw a polygone or ather figure in laser cut 5.xx and I engrave it it will fill the figure, what is not usable if you wana adjust the machine lest say for the acurate size, the laser spot size or so
I work around this when I set the settings to cut and the engraving settings then it just engraves a square line not filled
this safes me all the time to use corel and import it then
Re: Tips and Tricks
here are a trick how to fasten thin material to the tabel.
I used the kind of fastner what HD selles to fasten the white fiberglass wall panels
see picture.
see picture.
