Always connect to the negative side of the power supply. Don't do it on the Positive(+) side or it will blow it. See picture attached.
Some meter may comes with a little shunt (resistor). Just put it in series with the power supply and the tube. Then, connect the input pins from the current meter across on the two side of the shunt and you can read the current.
- MiniGrnVoltCo2.jpg (72.66 KiB) Viewed 7397 times
TeacDance
Ok thanx MarcoTech_Marco wrote:Always connect to the negative side of the power supply. Don't do it on the Positive(+) side or it will blow it. See picture attached.
Today works
and many test leather and acryl
Urbantrix
Hi Everyone,
I'm completely new here, I have also brought the K40 machine and want to upgrade it to use the DSP controller. Before i order all the parts i need to find out if i need to purchase the power supply suggested here on page 1 of this thread or if the power supply that came with it is useable, I have the same power supply in mine as tech_marco has in his videos
Thanks in advance
Thanks in advance
TeacDance
easier way to buy the power supply but if you want to use it as original as marco may help. power supply was easy to connect the three wires attached and ready to.Urbantrix wrote:Hi Everyone,
Thanks in advance
Now is a good post-combustion release token trolley i cut many those today
Urbantrix
I have decided to order the power supply as well, after looking closely at the current power supply in there the solder joints are so bad i think it would cause more problems in the long run
TeacDance
i think you do right decisionUrbantrix wrote:I have decided to order the power supply as well, after looking closely at the current power supply in there the solder joints are so bad i think it would cause more problems in the long run
TeacDance
did you have already components? Today the product itself 20pcs saunameter two different models
alder and radiata pine, the first CNC has the bottom and then the laser pattern.
Alder radiata pine
Alder radiata pine
Urbantrix
Hi All
I'm slowing going through the conversion process after receiving all the components today, however i am stuck on the ribbon wire and how it connects to the stepper motor driver.
The ribbon wire has 12 connecting points but I can see from photos already on this forum that only 4 are used but I cannot find which 4 I'm using tb6560 stepper motor drivers
Any help would be greatly appreciated
TeacDance
Urbantrix wrote:Hi All
i can look at morning in finland is now midnight 2:00 if marco faster he can tell that too
Urbantrix
Thankyou, I appreciate it, it's the last connection i need to do
TeacDance
Urbantrix wrote:Thankyou, I appreciate it, it's the last connection i need to do
I connect that ribbon wire like this
when lookin up to ribbon wire when connection is up reading right to left
12-11-10-9-8-7-6-5-4-3-2-1
9=motor red -> driver B+
10=motor blue -> driver B-
11=motor white -> driver A+
12=motor yellow -> driver A-
TeacDance
How to io port works? if i want to connect air blower example to it
Urbantrix
Thanks for all the advice Teacdance. I'm now fully connected up.
I tried cutting a basic circle to start with but when i sent the circle image to the laser it instead engraved 31 straight lines one above the other spaced about 0.5 mm apart and each line was 70mm long. No idea where it's getting that information from.
I then copied your settings on page 3 of this thread (as i have no idea how to program these things) and now it says "not enough extend space please esc" which i understand from an earlier post is because the image is to close to the edge of your usable area however i have tried moving the image to different parts of the page but still getting the same message.
TeacDance
You have to change cut if you want to cut circle not engrave..Urbantrix wrote:Thanks for all the advice Teacdance. I'm now fully connected up.
- 1.JPG (14.67 KiB) Viewed 7219 times
TeacDance
Here is my setup this moment those page 3 is my earlier setup
this setup works fine to me
manufacture parameters Control parameters
