Gweike power supply connections
brian257
Post by brian257 »
I am retrofitting a Gweike laser with a Lightobject DSP. The power supply has no marking as to what pin does what on the connector. I know the connector on the left is the AC input. Can anyone tell me what the connections on the right side connector are and what they should connect to on the DSP end? Of course on the old Gweike DSP there are no markings on the connector on that end either so I am completely without any information.
laser supply.jpg (103.33 KiB) Viewed 3894 times
brian257
Re: Gweike power supply connections
Post by brian257 »
Hmmm, just found a manual online for the Leetro MPC6515 DSP that was in the laser and it shows an analog output for the laser so my thinking is that I am going to have to replace the power supply with one that has PWM input unless someone knows different.
Post by Techgraphix »
Hmmm... where did you found this laser? Looks like it was on a junkyard for years... just curious.
brian257
Post by brian257 »
I found it on Craigslist for about $500. A guy had it in a shed in his backyard for a few years and rats and/or squirrels ate all of the wiring and belts. It was filled with leaves, shells from nuts, acorns, and rat turds. Mirrors were all oxidized. The tube in it didn't work, but had a spare new Reci tube with it and that works. So far I have added an LO DSP system, new power supply, and alll new optics and mounts with 35mm mirrors, 25mm head, and beam expander. I probably have $2,000 or a little more in it, but still half the price of a new Gweike, but a better laser than when it was new.
