Hi
Can someone please tell me what does Max Start Parameter in factory parameters exactly do ?
and can the datum speed on boot be changed ? if so, how ?
Thank you
Bruno
DSP T9 Max start and datum setup
Hydrops
yurirage
Re: DSP T9 Max start and datum setup
Bruno,
Surely by now you've figured it out, but just in case:
The XY reset speed setting is under User Parameters in the System Settings menu.
As for your other question - I can only assume that the Max Start value is the maximum commanded cold start speed, after which the acceleration value is applied until the commanded speed is reached. But that's merely assumption, and you know how good those are...
--Yuri
--Yuri
Users browsing this forum: Bing [Bot] and 4 guests
