Pro mount mirror adjustments
Is there a schematic available for what each of the knobs do on the 30mm pro mirror mounts. Seems I can adjust left/right but not up/down.
Re: Pro mount mirror adjustments
Undo the two hex bolts closest to the thumbscrews. They are for ‘double locking’ it in place. Unscrew the brass screws, turn your thumbscrews to position, repeat until it’s calibrated. Then lock the brass ones back and screw in the hex bolts.
