NO laser fire low voltage
RussDolan
Post by RussDolan »
just finished the installation of the awc708c light everything seems right except when I test fire the laser I get a low voltage read out on the laser power supply. I did double check the wiring and everything matches the installation diagram. the only difference is I'm using a 12volt power supply not a 24 volt. is that the problem?? I thought it would work with a 12volt one?
Re: NO laser fire low voltage
What is the "low voltage " were you referring to?
You sure don't want to measure the output voltage from the laser power supply without special equipment!
Did you select High output or Low output from the LaserCad/RayCam?
The controller board can take 12v-32v so 12 v for the controller power is not a problem at all
RussDolan
Post by RussDolan »
m new to the 703 everything seems perfect now just learning the software and setting up my mirrors etc. I dont know how to jurn my test fire down. I like using only about 10% during test fire i adjusted it in the setup but its still firing 100% any ideas?
RussDolan
Post by RussDolan »
the issue was the main laser on off switch btw
