wont chill. If anything, the temperature just climbs.
I have done a reset to factory parameters by holding up/down arrow
for a few seconds until the display shows rE.
When I power it up D1 is lit and D2 flashes for about 30 seconds.
After that, it sounds like the fan/compressor starts to run. D1 & D2
are solid and the display shows 24.XX C The temp climbs with run time
and doesn't drop, it should be cooling. I have confirmed the default
F0 - F9 parameters per the manual. I'm guessing the refrigeration
unit isn't working
Is this a setting issue ? or a Warranty issue ?
