Tube keeps firing
scottbgv
Tube keeps firing
Post by scottbgv »
My Laser starts firing as soon as it turns on. It was ok earlier today. I have been messing with the system options. When i hit the Laser (fire) button the laser shuts off while pressed.
Edit
I switched out DSP's and the tube acts as it should.
Could of my dsp of went bad? its the awc708c
fnaranjob
Re: Tube keeps firing
Post by fnaranjob »
Maybe the fire signal is inverted, either change the connection from H to L (or L to H I dont know what you have connected) in the laser power supply or change the logic in Lasercad, that is options/manufacturer parameters/TTL level
scottbgv
Post by scottbgv »
I will mess with it but its working with the old dsp right now and i got a busy couple weeks
i dont think its in the wiring because all i did was unplug one control and plug in the other
I was messing with the parameters i think i will try that thank you!
