Air Assist tube routing suggestions please
WVJoe
Post by WVJoe »
Can someone provide some pics or input on how they routed the air hose for the air assist?
I am trying to use the "Very Flexible" air hose provided with the LO-X7 kit but it seems that any way I try to route it, it bends and binds, catches on the rail, etc. I also bought one of those coiled tubes but it is not going to work, no room in this thing and it's also a little stiffer too and I don't want to put any un-due stress on the motors.
Any help is most appreciated.
Re: Air Assist tube routing suggestions please
You need a cable carrier so that the tube won't get angle and clogged
Currently, we carry large carrier but we will get smaller like 8mm on later July
WVJoe
Post by WVJoe »
Tech_Marco wrote:You need cable carrier so that the tube won't get angle and clogged
Awesome man! I have some 8mm that I was originally going to use for the x axis cabling but it wouldn't work. I'll post a pic or two when I get it done. Thank you very much Marco!
WVJoe
Post by WVJoe »
Here's an update on my air assist. Let me know what you think please... https://www.dropbox.com/s/60isjm4ah1882 ... 9.mov?dl=0
