Frame Kit Diagram
Harldave
Frame Kit Diagram
Post by Harldave »
I just purchased a frame kit but didn't notice a diagram to put it together. Is there such a thing on here??
litterbox99
Re: Frame Kit Diagram
Post by litterbox99 »
I just built the 900x600 and I did allot of "Stare and Compare"
to the pictures in the following links. On thing, you must think
ahead. It pertains to pre-loading the extruded aluminum with
the correct placement and count of the nuts, otherwise you will
box yourself in. You will understand once you start building.
viewtopic.php?f=16&t=1980
viewtopic.php?f=47&p=14692&sid=0014a314 ... e7f#p14692
http://public.iorodeo.com/docs/laser_cutter/index.html
Both of these links helped me for my build in all aspects....
here's a pic of my frame;
Harldave
Post by Harldave »
Yes you're right about the boxing in. It was like playing chess with a frame.. You have to think 4 moves ahead before making your next move.. Have you figured out what the " cover " parts are for??
litterbox99
I never figured it out.... but I have used some of
the leftover parts elsewhere on the frame.
Here's a pic of where I'm at now with my frame.
Harldave
Post by Harldave »
Nice job!! I'm skinning mine in.
