Any idea on when? I have the language file almost finished, And thought of a name yet? "LightObjects" "LO-DRAW"Tech_Marco wrote:Update: Ramp feature has been completed. But, I will not release it until a few more features completed. Plus, I have to launch the software in a new name other than 'LaserCad'. A few new features will be add-on and is free for customers who purchased from us within a year. For customer with who purchase 1 year or longer, the software will cost $30 an extra.
What is the difference between AWC-608B / X7 DSP / R5 DSP ?
DonL
Re: What is the difference between AWC-608B / X7 DSP / R5 DS
DonL
English Corrections to Language file
- LCAD english.zip
- (6.17 KiB) Downloaded 271 times
Thanks Don!
I'm thinking to launch the new software in between May 15th to May 30th when my PRO530 machine is completed (retail casing)
DonL
Well, if you would like someone to beta test before release, let me knowTech_Marco wrote:Thanks Don!
DonL wrote:Well, if you would like someone to beta test before release, let me knowTech_Marco wrote:Thanks Don!
Yes, I will send you a link to download it for testing. You need to upgrade the OS on the DSP as well
DonL
OK, I will watch for the messageTech_Marco wrote:DonL wrote:Well, if you would like someone to beta test before release, let me knowTech_Marco wrote:Thanks Don!
DonL wrote:OK, I will watch for the messageTech_Marco wrote:DonL wrote:Well, if you would like someone to beta test before release, let me knowTech_Marco wrote:Thanks Don!
I sent you the link to download the Beta LaserCad with ramp ready
SWMS
I'd be happy paying £30 for new software that saves the settings for different materials
DonL
Just as a note, Each color remebers the last seettings so if you want to save the settings for engraving glass for example, use yellow for the layer color then next time the settings will still be set from the last glass engrave.SWMS wrote:I'd be happy paying £30 for new software that saves the settings for different materials
SWMS
Yeah, I know but often I order cuts by colour, so having something that just loads it by material would be handy
DonL
Agreed, I have been asking for that as well, I think Tech_Marco is working on it so I don't want to hound himSWMS wrote:Yeah, I know but often I order cuts by colour, so having something that just loads it by material would be handy
jeffbrom
Hello All,
I'm interested in buying the LO-X7 controller.
After reading all the posts in this topic, I am wondering what the current status of the following list is?
Copied from Tech-Marco:
Here is list of things need to do in prioritize sequence:
1) Grey scale engraving feature. Note, it may not help on a regular CO2 laser tube RF tube
2) Convert the "U" drive for the rotary so that we don't need to disconnect the Y axis
3) Ramp engraving. This is a great feature for Stamp maker (I don't know why ramp is important for stamp making)
4) Text bugs. Some fonts can be picked but it won't show up once in place
5) Add a ruler to assist object positioning
6) Layer order. Current the engraving layer will cover cutting layer so that we can't see the layer behind it
7) Print Driver. This one will take longer to finish.
8) Enable "Shit + Stop" feature in the LaserCad menu
9) Add camera capture feature. By toggling the LaserCad screen, it will see the object from the camera. It is a great feature to be used to 'repair' cutting that being cut through and rework is necessary
10) Library. Add a data base so that a user can save cutting/engraving speed/power level per material.
11) English. Fix some grammatical issue or wrong term being used on LaserCad
12) Rename LaserCad. The "CAD" caused some confuse to some customer. Better rename it to better fit the control software.
13) Delete layer. Currently a layer on the drawing can't be deleted.
My Thoughts Are:
Number 7, Print Driver, would be very important to me, for use with CorelDraw, etc.
Number 2,3, 10, 9 and 13 would also be very useful.
Jeff
My Thoughts Are:
Jeff
