What are these parts for?
s2jesse
I ordered a K40 upgrade kit with a x7 and i got these two parts but i dont know what they are for?
Thanks Jesse
Thanks Jesse
s2jesse
Re: What are these parts for?
oops never mind i just figured it out when i went to mount my X7
They are mounts for the main control panel.
Jesse
Jesse
Can you post a photo how you placed them? I still haven't figured it out..
bonnette_l@yahoo.com
I'm pretty sure they are to hold the display in the chassis.
Yes, A photo would be nice.
I never used mine and would like to see how they are supposed to work
Larry
Larry
gadman58
If you tighten the screw it always falls out (the way it's shown) Maybe the screw needs to go in the other way on the bracket ?
Thanks for the picture
Larry
Larry
If it's placed like on the photo it will fall out, if you reverse the screw it could work if it was reachable from the top.. But there is the front.
If you want to tighten it from the bottom, so the hinge is pointing the other way, the screw end "walks"..
I solved it by making similar hinges, but with the nodge the other way around, drilling two small holes in te mountingplate and turn a point at the end of the screw that will fit in the small holes..
Now i'm able to fix the panel tight to the mountingplate..
But as they came?? not usable IMHO ... Until someone shows me how to use them properly, i'm not convinced it works with this panel..
gadman58
This set up is very simular to the Cmore screens from Automation Directs .
The above picture is the R5 screen. They seem to stay in ok.
I don't have the panel built yet still working on getting things set up.
Clamped this piece of Al in and it held firm.
Maybe the slots in this one are narrower than some of the other DSP screens.
I don't see a reason you can't turn the screw over and have the hook keeping it from popping out.
Did notice these angled some maybe that is keeping it in as well.
Glenn
Glenn
- IMG_0865.JPG (81.47 KiB) Viewed 4531 times
gadman58
Thinking more on it.
With the screws flipped the other way the side legs would take up the force applied on the screen.
Yep certainly is better.
- IMG_0866.JPG (69.97 KiB) Viewed 4530 times
The case of this display is slightly different from my X7-display. When i turn the hinges like on the latest picture it almost has nothing to lean to.
For this display it works like you fitted it now.
As an extra you could turn or grind a point to the screws and drill a small hole in the panel to hold the point in place..
This is what i did with the screw's tip to fit in the small hole in the front: This is how the hinge fit on the X7-display: Kees
