Part list and assembly instruction for the 600x400 aluminum case. It apply to 900x600 as well except for the dimension (part list)
600x400 aluminum frames case part list and assembly guide
- Aluminum Farme 640 Setup Diagram 20140312.pdf
- (201.63 KiB) Downloaded 901 times
- #640 Draft Dim 20131226 2.pdf
- (531.32 KiB) Downloaded 524 times
- #640 case solid a1.jpg (131.46 KiB) Viewed 9481 times
- FrameMain500.jpg (223.32 KiB) Viewed 9488 times
Re: 600x400 aluminum frames case part list and assembly guid
Update: where is "T" & "L" bar installed to?
