So my old import tube was losing power, so I decided to spend the cash and just buy a 130W tube and supply from Light Object. Got the Tube and power supply installed and fired it.. with 5v on the in pin it maxes out at 9ma.... I tried the current limiting pot and it has no effect.
Checked all the connections with a ohm meter and there is a good connection.
Any ideas?
New 130W Reci Tube and Power supply maxing at 9ma
rtavk3
Re: New 130W Reci Tube and Power supply maxing at 9ma
Most likely you're using AC220V PSU on AC110V oitlet
Double check it
Which power supply did you purchase? It came with power pot? I didn't know it
Double check it
rtavk3
LSR-RECI-P16 RECI P16 CO2 laser power supply. Support Z6 1 $389.00
Nope the psu says the input voltage it is receiving and it says 237Vac..
Then, did you ground the TL or applying +5V to TH?
rtavk3
the 5v line is tied to TH, the laser if firing, it is just doing so at a super low amperage. I have added a pic of the tube and the readout of the psu..
- 2014-10-02 19.17.20.jpg (94.37 KiB) Viewed 2715 times
- 2014-10-02 19.16.54.jpg (138.69 KiB) Viewed 2715 times
