Upgrading a 40w laser tube?
Craig_Johnson
I recently converted an FSL MLE-40 to use the AWC 608 controller. The manual on the old laser says that operating the laser above 15miliwatts will shorten its life. It was able to cut thru 1/16 acrylic in a single pass but I never checked the wattage. Now I have the wattage set to 23% and it runs 15.7 miliwatts, but takes 5 passes at 50mm/sec to cut. Making a page take 20+ minutes to cut for .060 acrylic with two layers of lamination on each side. I'm thinking I could replace the 40w tube with a 60w tube since I have already bought the 20w/40w/60w powersupply. Any thoughts on that?
swamidog
Re: Upgrading a 40w laser tube?
i have no problems cutting 1/16th acrylic with my 60W tube at 18mA power with a single pass at 10mm/s.
http://youtu.be/kl05Yo-VGhA
Craig_Johnson wrote:I recently converted an FSL MLE-40 to use the AWC 608 controller. The manual on the old laser says that operating the laser above 15miliwatts will shorten its life. It was able to cut thru 1/16 acrylic in a single pass but I never checked the wattage. Now I have the wattage set to 23% and it runs 15.7 miliwatts, but takes 5 passes at 50mm/sec to cut. Making a page take 20+ minutes to cut for .060 acrylic with two layers of lamination on each side. I'm thinking I could replace the 40w tube with a 60w tube since I have already bought the 20w/40w/60w powersupply. Any thoughts on that?
NickWL
I have no trouble cutting acrylic a good deal thicker than that on my K40 (35 watt) at around 13ma and 15mm/sec
brian257
Do you have PPI turned on? My 60W power supply and 40W tube runs about 34 o0r 38% to get 18mA. You should be cutting much better than you are.
Craig_Johnson
It was a busy weekend, but I do have some results that seem to give me what I want:
20% power yeilds 14.7 miliamps (within the range FSL specified for the tube)
15mm/sec
2 passes
This takes 24 minutes, which is not accecptable.
I have 2 questions - what is PPI? and can I simply swap out the 40w tube for a 60w tube with the 20/40/60w power supply I purchased here?
15mm/sec
2 passes
NickWL
I have 18mA marked on my cabinet as the maximum for my K40-supplied laser tube. I try to max out at 17mA.
The upside of burning out the tube? I get to build a BIGGER laser cutter!!!
Craig_Johnson
OK, so I set the PPI setting to 600 and with the power set at 20% I get 8.5 miliamps on the tube. I am able to push the power percentage to 50% and get just under 15 miliamps but I have not done enough testing to see if it will cut any faster. One thing I noticed is that because I have two layers of lamination film on each side of the .060 acrylic, the back side gets a slightly postage stamp effect. The beam thickness on the back side is at least half the width of the front. More testing will tell.
Craig_Johnson
Looks like all the 60w tubes are 1200mm long and simply won't fit into my 40w case which uses the 700mm tube. Beam diameter is also bigger, I suppose focusing would tune that somewhat.
Might as well plan on moving to the 4x8 sheet of plywood version. I guess I'll be making due with what I have for a while.
When you enable the "PPI", the cutting power will be dropped by a lot, 50% to 75% depends on the frequency. If you couldn't cut well without PPI, you will get worst if you enable it!Craig_Johnson wrote:OK, so I set the PPI setting to 600 and with the power set at 20% I get 8.5 miliamps on the tube. I am able to push the power percentage to 50% and get just under 15 miliamps but I have not done enough testing to see if it will cut any faster. One thing I noticed is that because I have two layers of lamination film on each side of the .060 acrylic, the back side gets a slightly postage stamp effect. The beam thickness on the back side is at least half the width of the front. More testing will tell.
