large variance in PT100 probe readings
Posted: Sat Dec 03, 2011 9:31 am
I recently bought three PT100 probes and three JDL612 PID controllers. I also bought one of the waterproof probes that consist of a plastic tube protecting the sensor. (I am making sous vide controllers for holiday presents.) After setting them all up, I was trying to set the input offset (PSb) for each one and was surprised at the variance in the readings. I used a human temperature taking thermometer to calibrate all the probes, figuring the temperature reading within 0.2 degrees was close enough for calibration purposes.
I have a personal sous vide controller and probe from a previous build, resulting in a sample size of five. I use a water bath of about 100F to calibrate the probes. The offsets in degrees F:
-2.7 (water proof probe)
6.6
1.0
51.1
0.2 (my original probe)
Clearly there is something wrong with the probe that requires a 51.1 offset. I checked the wiring and the red wire does go to #8 terminal on the PID. I have not checked the impedance for fear of damaging the probe. Tested in another controller showed a similar erroneous reading. Is there another way to confirm there is a problem?
The second reading appears to be suspect as well. I can add an offset but worry the range or accuracy of the probe may be compromised. Is an offset of 6.6 degrees indicative of a faulty probe or can I use it with confidence?
thanks,
Michael
The Sands Mechanical Museum
6.6
1.0
51.1
thanks,
Michael
