EWP-D50C124030L DC12V Water pump with control
admin
Site Admin
Post by admin »
Specification
Power: DC12V (15V max)
Current: 3.8A@12V
Output: 30.0L/m (475 GPH)
Pressure: 6.0psi @12V
Motor: DC 3 phase coil, more torque and quiet
Power: 45Watt
Speed control(3 wires): 0-5V analog
Shaft: ceramic
Intake: G1/2 (1/2")
Outlet: G1/2 (1/2")
Life span: > 20,000hrs @ 1600rpm~10,00rpm
Noise: << 35dB
Working Temp: 100'C/ 212'F (not submersed)
Envir Temp: <50'C
Size(L*W*D): See "More images for the exact dimension"
Weight (net): 16.0oz
Note: Red + 5V, Black 0V, Yellow: speed control. Use a 10K ohm 1/2W variable resistor (yellow to the center tap) for speed control.
Warning: Do not let it run dry without water!
EWP-D50C124030L_Manual.pdf
(144.71 KiB) Downloaded 1170 times
Return to “Water pump”
