This is a temperature controller specially designed for Solar water heater system. It support dual temperature input; one for the solar output and another one for the water tank. Also, there is a relay output for the water pump.
Note: the sensor probe must be PT-100, it won't take other probe type like K or J
JLD615 Temperature Controller for Solar Water Heater
- JLD615_Eng.pdf
- (297.96 KiB) Downloaded 1667 times
