PID controller - cannot increase input temp above 40*C
Posted: Fri Mar 18, 2011 8:55 am
by chriskennedy82
Everything else works, I simply cannot get the input temperature to move above 40*C. I am using a pt100 RTD temperature probe
Re: PID controller - cannot increase input temp above 40*C
Posted: Fri Mar 18, 2011 10:43 am
by richiem
So everything isn't working. We just need more info from you about your set-up. No one can hope to successfully offer advice when the trouble is "it doesn't work." A list of your controller settings would be a good place to start, plus a description of your components and connections.
Posted: Fri Mar 18, 2011 4:22 pm
by chriskennedy82
Fixed it... found "another" manual for the controller that gets at all of the sl codes.
Cheers,
Chris
