5740 amp meter
fergusson1
5740 amp meter
Post by fergusson1 »
I have a sollar array that is producing about 65 to 75 amps so i bought a 5740 amp meter i followed the instructions hooked for the Case 3 dia. entered each password made sure that each Set point read the way the instructions say they should. The meter reads 499.9 to500.0 this iis not the reading I should be getting so I double checked the instructions going thru each step still get same reading HELP PLEASE
Re: 5740 amp meter
What is specification of the shunt you have? 100A 75mV may be?? Or something else? The setpoint has nothing to do with the reading. It's for the alarm output.
fergusson1
Re: 5740 amp meter
The shunt is a 100 amp 75 mil.
Re: 5740 amp meter
First of all, select Signal type to '3' using password 0089
Try the following setting (display only):
PvL: 0
PvH: 100
dot: 1
Filt: 0
The max display it will show is "100.0"A
fergusson1
Re: 5740 amp meter
isnt this password 36 ?
Re: 5740 amp meter
Then do the other with 0036.
Please follow the manual step by step
fergusson1
Re: 5740 amp meter
Thank you Marco IT WORKS!!!!!!!!!!!!!! one more question I need to mount the shunt can I drill a 1/8 hole in the center of it without ruining the integrity of it ?
Thanks again
Re: 5740 amp meter
You can drill the hole on the fixture that holds on the shunt. The size of that pieces of metal (shunt) is precised calculated so don't do any change on it.
fergusson1
Re: 5740 amp meter
Tech_Marco wrote:You can drill the hole on the fixture that holds on the shunt. The size of that pieces of metal (shunt) is precised calculated so don't do any change on it.
marco
why does this 5740 blink? and how do I fix it
Re: 5740 amp meter
I'm not sure what you mean of blinking on the 5740. Can you video it please
Return to “Electronics”
