PID help needed !
robinhood
PID help needed !
Post by robinhood »
Not sure if I am on the right track programing the TCG-6131P so I thought best if I just upload it here and show you the default and my current setting, and hopefully I get some input on it.... Something is not right cause as soon as I connect the heating wire to the heater relay starts working for a very short time and then the relay stays on longer than supposed to so I have to turn the thing. The value on the Pv side keeps going down to Zero then back up again while still heating. I heard a lot of good thing about this PID... I know it gotta be me!
CTG-6131P spec.pdf
(66.04 KiB) Downloaded 358 times
PID on at 33°c (2).pdf
(919.64 KiB) Downloaded 365 times
PID 2 of at 33°c.pdf
(1.95 MiB) Downloaded 315 times
