RECI W8 180W tube issue
chuck767
Post by chuck767 »
Was cutting at about 40% power and after about six minutes the laser quit cutting.
It has been working great up until this incident.
Any suggestions on where to start troubleshooting this issue?
Chuck
Re: RECI W8 180W tube issue
Is the laser power supply still working? Fan turning?
chuck767
Post by chuck767 »
I just realized I hadn’t replied to this question.
Yes the fan was spinning.
Here is the latest update. Although the fan was spinning I ordered a new power supply from “light objects“.
The new power supply is installed in my laser is again Cutting.
I had sent this email to Marco and I’m still interested in the questions that I have asked. Please advise.
“ Marco,
My previous note to you several days ago (unanswered) mentioned I found a burnt high-voltage connector on my existing RECI power supply wiring.
I had presumed this was what caused my laser tube to quit firing. I rewire the existing RECI Power supplyPower supply and to my surprise my problem dDID NOT go away.
I install the new “light object” power supply and everything works fine now.
I have a question, do you think the open circuit situation on the high-voltage electrical connector was what caused my RECI power supply to fail?
If so, what can I do to prevent an high-voltage Open circuit failure on my new power supply set up?
Is there a recommended way of splicing the high voltage wire?
Chuck
Users browsing this forum: No registered users and 79 guests
