Will Lightburn run LO X7 Raycam
darrenm2
Post by darrenm2 »
HI I have a K40 with LO x7 upgrade running Raycam and would like to know if it possible to run Lightburn. I have down loaded Lightburn to evaluate and get an error message that laser is busy when i send job. Can i make lightburn work or do i need a new controller.
Thanks Darren
Re: Will Lightburn run LO X7 Raycam
I'll say LightBurn will work on X7. You need to close Raycam or LaserCad before you can use LB.
If you still have the issue, you may want to patch the X7 and make it run on LaserCad but not RayCam.
Anyway, there is no more upgrade for the RayCam so it won't be a bad idea to switch back the X7 to standard LaserCad
