Using EWP-SNR108 for low flow trip
Posted: Sun Jan 09, 2011 11:52 am
I have ordered above flow device but need advice on electronics to do the following:
I want to trigger a relay when flow gets low (on a engine cooling system), would be good to be able to display flow (but not essential). Would need to be able to "calibrate" trip point. Whole thing needs to be small 1/16 DIN if panel mounted.
Is a frequency controller an option to do this?
This is on 250 Superkart, I have used the JLD 7100 (12V dc) controller to great effect on fan control on the same sort of cooling system.
