Hi
I have a DSP LO-X7 (AWC708C Lite) currently on Version 1.16.12.10(LO)
Last file I had for upgrade was 161210LO.UG5
is there a newer version of the firmware available?
Thank you
Sandra
Latest Firnware for Lo-X7
smgvbest
CortezK
Re: Latest Firnware for Lo-X7
Have you checked the download pages for that model, Sandra?lawrencejeff wrote: Sat Nov 12, 2022 6:20 pm I look forward to using mini excavators and have the same firmware on mine and am looking for an upgrade- did you find the correct one?
I see the RAR file in the downloads and I can download it but the text says for controllers only running lasercad. Mine works with Raycam and I thought you had to have it sent in to make it work with lasercad
Can anyone confirm if one running the LO firmware can upgrade to the one here
viewtopic.php?f=55&t=4133?
I don't care about lasercad or raycam - I use lightburn
Want to upgrade the firmware as I am seeing some weird things on the Z axis
smgvbest
Yes, none will load
lawrencejeff
I have the same firmware on mine and am looking for an upgrade- did you find the correct one?
https://www.lightobject.info/viewtopic.php?f=55&t=4133?
