what would be a way to verify if my JLD612 is functional?
Posted: Sun Dec 26, 2010 7:38 pm
I've spent more than 2 weeks reading this forum, trying to figure out how to make the JLD612 working.
I need to control temperature in the Crockpot. Using J type thermocouple.
Connected 110v to contacts 1 and 2, thermocouple to contacts 9 (red contact) and 10 (blue one), and SSR relay's 3-32 v inputs to controller's contacts 6 and 7.
Connected relay for testing purposes to a table lamp instead of a crockpot to verify if it'll automatically switch the lamp on and off by changing temperature.
Other settings:
Set 0089:
Inty: J
Outy: 2
HY: 003 (don't understand what it is, but looks like it does not affect anything)
Psb: 0
Rd: 0
CorF: 1
Set 0036:
SV: 70
AH1: 72
AL1: 71
AH2: 69
AL2: 68
Temperature controller starts up, shows the desired and current temperature, AL1 and AL2 indicators goes on and off when temperature goes up through 68 and 72. I hear clicking sound when the temperature becomes 70, but nothing changes on contacts 6 and 7 which supposed to make SSR relay to switch the lamp off when it's over 70 degrees F  only the clicking sound. "Out" indicator is blinking sometimes when the temperature is below 70.
When I use a ~9v battery to trigger the relay  I can verify the relay is working. But seams the temperature controller does not produce promised 8 volts on contacts 6 and 7  I can't measure anything meaningful by the voltmeter there.
I have two theories:
- either I'm doing something wrong, or
- JLD612 is not working as supposed to.
The question is: how to verify if the JLD612 functional (and I mean properly working, not just showing me the temperature and clicking when I need it to stop sending 8 volts to a relay)?
Or  if it's not, what is the procedure to ask for a replacement?
I bought directly from the lightobject site on December 6, 2010, and received few days later, and trying to make it working since then.
Other settings:
Set 0089:
Inty: J
Outy: 2
Psb: 0
Rd: 0
CorF: 1
Set 0036:
SV: 70
AH1: 72
AL1: 71
AH2: 69
AL2: 68
