Lightobject LaserSoft (T9) beta with 're-cut' added
Re: Lightobject LaserSoft (T9) beta with 're-cut' added
Beta 2: Oct 11,2018
Fixed: only one new layer will be created for the same layer (same color)
Minor twisted:
1) Support 12 chars on naming a job file
2) Allowing changing multiple layers setting(speed & power) by picking any layer for editing
3) Allowing adding cutting notch by using 'Right click' from a mouse
download/DSP/Ph/LOLaserSoftV7.22.0.zip
Re: Lightobject LaserSoft (T9) with 're-cut' added
With this version, the style of 're-cut' feature has been changed. Instead of modifying the original object by adding two new break point, the new re-cut will duplicate the area instead. The selected area can be removed easily.
Note that all re-cut section the speed is 40% faster than the original speed. User can change it at will. For example, if the original cutting layer is set to 20mm/s. The re-cut layer for that particular layer will be raised to 28mm/s. Reason is that the 1st cut was not being cut through completely but closed, say 90% done. Therefore, we should either set lower power or raised the speed for the 2nd cut. Make sense? I choose to raise the speed faster so it complete the job faster.
Marco ;)
10-27-2018
download/DSP/PH/LightObjectV7.22.2.zip
Return to “DSP Laser Controller”
