Lightobject 800W Chiller and Antifreeze
gandyman
I have the LO800 Chiller and have been looking to make sure I can use antifreeze in it. I understand I need to use RV Antifreeze and have purchased Splash RV and Marine Antifreeze, but want to make sure it is okay to use in the LO800. If so, what would be a good mixture? I have looked in the forums but do not see it being okay to use in the LO800. Do not want to damage it or void my warranty.
Re: Lightobject 800W Chiller and Antifreeze
I suggest 1 : 10 . My first suggestion of 1:5 q while back ago. For 1:5, it may cause minor erosion on the intake/outlet connectors. Plus, you should flush the chiller every 3 months
