Element E5 dsp water protect wiring question
Posted: Fri Oct 28, 2016 1:06 pm
by Dennis1979
Hi all,
This is my first post here, I bought a Element 5 DSP upgrade kit for my K40 laser engraver.
After 3 weeks of hardware fine tuning, I started today with the wiring. 220v wiring was no problem, but I encounter problems wiring the Water Protect switch.
Do I have to wire the WP switch to the PSU? Or can short the WP wires on the PSU and wire the WP switch directly to the DSP controller (to pin WP and pin GND?). I currently wired the lid (safety) switch to the PSU.
Re: Element E5 dsp water protect wiring question
Posted: Sat Oct 29, 2016 2:01 am
by Dennis1979
After searching a great part of the internet, I'll just wire the lid and the WP switch directly (in series) to the PSU, and no wiring to the dsp controller.
Posted: Sun Oct 30, 2016 11:53 pm
by tansh
Do you have a water protection flow switch in place? If yes, then connecting it in series from WP to GND at the PSU. If not, then just jump with a wire from WP to GND at the PSU. This is a safety measure to ensure water "always" flows into the laser tube before laser firing up. Firing laser without cooling water would probably crack the tube, be careful.
Posted: Tue Nov 01, 2016 4:44 am
by Dennis1979
Thanks, the machine works, but still having problems, I open another thread in K40, think that is a better place for it.
