Converted the one on the forum to an STL that I could print
http://www.thingiverse.com/thing:1808025/#files
You'll need to drill out the limit switches with a 3mm drill bit. These are the switches that I used:
https://www.amazon.com/gp/product/B00E0 ... UTF8&psc=1
power z table limit mount (3d printed)
pw98
bonnette_l@yahoo.com
Re: power z table limit mount (3d printed)
Thank you very much pw
I intend to use this
Larry
Larry
pw98
I'll upload a different model with smaller holes for those that do not intend on using heat-set inserts
