hello new build am I forgetting anything...?
Posted: Mon Apr 25, 2016 5:19 pm
by Patrick-mc41
1.X7 DSP Controller card for CO2 Laser Engraving/ Cutter with color screen
2.100W~180W PWM CO2 Laser Power Supply
3.600X900 Honeycomb for CO2 Laser Machine
4.XLE 900*600 XY Stages complete kit for DIY CO2 Laser. 2 yrs warranty
5.Lightobject 1600W Water chiller for CO2 laser machine (AC110V 60Hz)
6.SPT C100 100W CO2 Sealed Laser Tube.....
any help be appreciated My first Laser build
thnx Patrick....
Re: hello new build am I forgetting anything...?
Posted: Mon Apr 25, 2016 7:45 pm
Extra parts needed:
1a. Dual 36V/24V DC power supply
4a. Two (2x) 3MD560 3phase motor drivers
4b. Three (3x) 25mm Si reflection mirrors, one(1x) 20mm high quality ZnSe focus lens. You decide what focal point needed. Popular is 50.8mm
50.8mm OK to handle 4mm cutting or thinner object (less slope obviously) and good engraving. To do cutting on thicker object , you may consider 63.5mm or 68.5mm. But, longer focus lens take more power so you may end up running slower speed to offset the power dropping.
5a. Water tubing and air tubing
6a. Air pump
7a. Signal wires, 2-wire,3-wires,4-wires
Optional:
8a. SSR (solid state relay) and heat sink for main power control?
9a. Emergency switch?
10a. EMI filter
11a. Beam combiner (red dot targeting)
