Rotational > dimensions wrong after x7 firmware upgrade
Posted: Mon Feb 01, 2016 10:28 am
Hey,
i recently upgraded my x7 to the latest firmware. Today i wanted to use my rotational adapter and it did not work as expected. The dimensions of my lasered object are totally wrong. According to my screenshots i used
Rotate axis con (um): 3.750
Step per rotate: 1000
Current diameter: 200
before
which worked fine. Rotate axis was a bit of guesswork since my calculation said something else but this worked.
Now i just cannot find any usable values. What can i do? I recognized, that the values i entered in lasercad (like steps / rotate and diameter) are not the same as in the laser even if i change them. Is there a bug ?
thank you for helping,
tm
before
tm
