Need help going from MPC6515 to AWC608
Posted: Mon Nov 30, 2015 2:18 pm
I am switching from a MPC6515 control board to the AWC608 control board. I have most of the wiring figured out, but I'm stuck on the limit switches.
I am having a lot of trouble tracing the z wires back. There is no limit switch for my z table that I can find. I suspect the z wiring is coming from the autofocus. The AWC608 diagram shows two z limit (proximity) switches, but I think I only have one.
Would I be correct in assuming I just need to connect the two grounds on x and y and I don't need all the green wires there?
What do I do with the z wiring?
PDF for the AWC608 diagram
