I started this project a couple years ago and I just don't have the time to finish it. 2ft x 3ft cut area, Reci 80 watt laser tube for fast, thick cutting. Everything I've bought for this project is included. Nearly $2,200 worth of brand new parts. Basically all you need to finish is mount the laser tube in the back, fabricate adjustable carriage for the honeycomb platform, get some more extruded aluminum for enclosure structure, cut some aluminum for the outer skin and wire it all up. It needs no more than $300 and some time and you'll have yourself a machine that rivals 8-10 thousand dollar machines.
Parts receipts can be seen in the link below.
https://drive.google.com/a/iehomebuyer. ... sp=sharing
