Machine Size in Lasercad greyed out (LO-X7)
Posted: Wed Oct 21, 2015 1:40 am
by typomaniac
Hello,
i am currently setting up my LO-X7 unit and i wanted to define the machines size in order to make the soft limit work (i assume that the machines size is needed for software limit switches?). Where can i set this up in LaserCad 7.65? I found »options > default parameters« but this is greyed out.
Thank you!
Tm
Re: Machine Size in Lasercad greyed out (LO-X7)
Posted: Wed Oct 21, 2015 1:58 am
by Techgraphix
You have to set the machine limits here:
Options > System Options > Manufacturer Parameters > Range X, Range Y and on the page Z/U Axis Options, you can set the Range for Z (and U)
First click on Read to read the data from the controller and after you set them, click on Save. You have to enter the password 608
