Can the Power Table be modded?
Posted: Sat Oct 17, 2015 9:56 pm
I have some tall bent anodized aluminum parts I want to engrave. My plan was to just cut out the bottom of the enclosure and have a manually adjusted platform hanging underneath it, but this power table looks great and is priced right for me. My question is if I get the power table, could the parts be modded for more lift extension? I.E. are the lead screws press fit/permanently attached or could I swap them out for longer ones? Also could it be bolted to the underside of the enclosure and with an open cut out, to facilitate taller objects?
Thanks for the help.
