AWC608C Problem
Posted: Wed Oct 07, 2015 5:29 am
Hello, I've bought a AWC608C laser board controller for my laser.
I use n° 2 Leadshine easy servo motor ES-M32320 (http://www.leadshine.com/productdetail. ... =ES-M32320) with their leadshine driver ES-D508 (http://www.leadshine.com/productdetail. ... el=ES-D508).
I have a problem with the AWC608c control. I can't reach high rotation speed of motors, and also the motors showcase an abnormal running. You can see it in the attached videos. With the AWC608C controller, the motors can't run more than 5 rps (revolutions per second).
Instead with a direct control of the driver of the motor (through a Protuner software) the motor can reach 50 rps: see it in the attached video.
The motor are set 51200 pulse per revolution. At 5 rps the pulse frequency is only 256kHz. I've read in the specification of the control board that the max main frequency is up to 150MHz.
What's the problem? I've made something wrong? Can someone help me please?
https://youtu.be/dXIo0wTvFx4
https://youtu.be/hgi1btvscqQ
https://youtu.be/z0SVyEekTYU
