Pin hole HOW? SOLVED
funhawke
Post by funhawke »
Any one know how I can do a pin hole. I have a great number of ribbons and need to have the PIN in the same position on each one. Is there a way to make a "laser shot" on the material like you would when you push the laser button on x7.
I use corel to start with.
Re: Pin hole HOW?
How about a circle with a diameter of 0.0001mm and lasercut that speed 1 80% power.. sure you wil have a pinhole..
