The "Rotate Engrave" function found under "Advance Functions" now works as it should. On "Engrave", "Cut" and "Run Box". Previously it only worked on "Engrave"
I have now got the AWC708 controller rather than the older AWC608 which I had when first doing rotary jobs.
So it may be that this was fixed in the new 708 controller. But I suspect it has been fixed on both controllers via firmware. I have no way to confirm that as I no longer have the 608.
The reason I did not realise that this was fixed, or WHEN it was fixed is that I have always used a work around to avoid this bug when doing rotary jobs. That is to alter the step um value for Y axis to suit job diameter.
Anyone know when this was fixed? Or if it was fixed in the 708 or both controllers?
That is one of the problems of not having a changelog for the software. You never know what changes have been made. Until you stumble upon them.
My Thanks to whoever fixed it.
"Rotate Engrave" now works.
Greolt
prcdslnc13
Re: "Rotate Engrave" now works.
So does this work using the U axis or does it still require the Y Avis?
Users browsing this forum: No registered users and 74 guests
