dsp laser controller and servo motors
Posted: Wed Aug 04, 2010 9:27 pm
by creativecorp
Hello, I have a mach 3 home built laser system running gecko servo drives and servo motors. Is your dsp laser controller compatible with servo motors?
thanks
Scott
Re: dsp laser controller and servo motors
Posted: Thu Aug 05, 2010 8:10 am
Yes, it does. Go to the manual section and down the manual.
Posted: Fri Aug 06, 2010 3:21 am
by creativecorp
Thanks Marco.
I have read through the manual. I think the manual makes mention that the motion controller board "could" be used to control 2 motors per axis. I have a gantry that uses two motors for the x axis, each driving its own ball screw, one is set as a slave. The y axis only uses one motor. Do you know if this can be done with the motion controller board?
Scott
Posted: Mon Aug 09, 2010 8:54 am
I was told that the support can support two X driver and one Y
