Hello all,
I am getting ready to upgrade my AWC-608 and LaserCad from 7.36 to 7.60B. Are there any steps needed before proceeding? Not sure if the update is an incremental update or a full one. Any step needed before updating the AWC-608 DSP?
I've been out of touch for a bit so not sure, just don't want to brick my machine.
Thanks!!
Upgrading from 7.36 to 7.60B
jjpumphrey
Re: Upgrading from 7.36 to 7.60B
Missed this post, but, anyway...
It's always save to write down (or make a screencopy) of all your settings. When you installed 7.60B you can check if all settings are still there. They should be in your controller so when you read the settings from the controller they should be un-altered. But if there is a difference you can set it again according your old settings.
It is also wise to update your firmware to the latest version.. But do that only after you have written down your old settings.. and check if they are all still there after the firmware-upgrade..
