parameter settings dsp display and thru lasercad.
Posted: Mon Jul 27, 2015 10:19 am
by paulburzynski
When you make a change to one of the machine parameters thru
Lasercad and click" save", do the same parameters change on the dsp display or do you have to enter those indipendently? I noticed the "apply" key is not functional? Is that mormal?
Thank you!
Re: parameter settings dsp display and thru lasercad.
Posted: Mon Jul 27, 2015 10:38 am
After Save, you need to 'Reset' the DSP by press the "Reset" button on the DSP or on LaserCAd
Posted: Mon Jul 27, 2015 3:35 pm
by paulburzynski
The datum button on laser cad is the reset button?l
Posted: Mon Jul 27, 2015 3:36 pm
Yes. Or, the "RESET" button on the LCD panel
Posted: Mon Jul 27, 2015 5:24 pm
by paulburzynski
I'm able to jog the gantry from both the computer and the lcd panel.but I still get an error message when I try to send the cut file to the dsp or when I copy it to the thumbnail drive and then try to run it..although a preview shoshone up on the lcd when using the thumb drive.. when I try to cut the file I get the error message. I will email you some screen shots so you can look at the error messages and the machine settings.
Thanks.
