LO-X7 OS patch.
paulburzynski
LO-X7 OS patch.
Post by paulburzynski »
Hi guys,
Do I have to load the LO-X7 OS patch to the dsp through my compurter..or do I copy it to an empty fat32 thumb drive and plug it into the dsp? The LCD display? will it recognise the thumb drive and down load the file without sometype of command?
Thanks!
Re: LO-X7 OS patch.
You download the patch and unzipped it to a USB memory stick (Format in FAT32)
Press the "Menu" button on the LCD unit and pick UDisk, where you will see an option for Upgrade. It will detect the upgrade file.
Note: Erase all files in the DSP before applying the update!!
paulburzynski
Re: LO-X7 OS patch.
thanks Marco.. I will try it... I have another question and will do it as a separate post...
Users browsing this forum: No registered users and 53 guests
