Looking for better laser
Posted: Tue Jun 09, 2015 11:20 am
I have been very happy with my Lightobject conversion for my K40 laser, but I would like to upgrade to something bigger, faster, and better. I have seen samples cut and engraved on Epilog and other RF lasers and my K40 can't get close to the results nor would I expect to for the money I have in the K40. I am trying to decide between getting a commercial RF laser system like the Epilog or building my own with a Lightobject 1200 X 900 stage and an 80-100W tube and of course a Lightobject DSP.
I know that if I go with the homebuilt version with the above parts that my cuting and engraving speed will go up drastically from my K40. What I need some advice on is will my quality for fine engraving of small letters and intricate cutting go up or go down? And if it would go up will it still be much below the quality of an RF laser. I don't really know for sure if I would expect quality to go up or down from what I am getting with the K40 because there are a lot of factors involved. Not sure of the positioning accuracy of the better quality although much larger stage, will the larger tube outputting very low power for engraving give me better or worse beam quality than the smaller tube, will I be able to run the faster stage at a high speed and still get the same accuracy as going slower with laser having to turn on and off at a much higher rate, etc.
Let me know some opinions and feel free to post some pictures of fine detail results from those that have the bigger stages and more powerful tubes.
