Z-axis Pulse Unit Setting Not Adjusting Z distance correctly
Posted: Sun Mar 08, 2015 4:51 pm
I have a 2012 version DSP controller that I have finally taken the time to get powered up and working. I am 98% complete on my custom laser machine, and currently trying to correct the Z table distance.
I am running 4 Nema23 steppers off of two MD882ES drivers. Each pair of steppers are wired in parallel. The two drivers are also in parallel. I have confirmed that the movement is synchronized nicely as long as I use a low speed and stay over 2500 steps/rev resolution. I encounter synchronization problems if I try to run less steps per rev, and over-amp the circuit and stall the steppers at higher speeds.
I can only achieve a large difference in the z-axis distance by changing the step/rev resolution on the drivers. The pulse unit setting will adjust the z-axis to a point, but then the setting number becomes so low that the distance stop changing all together.
What is the assumed default setting for steps/rev?
Here is what I am doing in order to figure out the correct setting: (I am driving a 3/8-12 ACME screw to lift the table)
1 rev / 2500 steps * 1 inch / 12 revs * 25400 um / inch = 0.84667 um/rev
This pulse unit input does not move 10mm in inching mode. So I started at the lowest pulse unit the software will take (0.01) and progressed the number up until I finally got a significant change in the z-axis move distance. Here are the results:
Pulse Unit Distance Moved
0.01 8.39mm
0.05 8.39mm
0.1 8.40mm
0.5 8.46mm
1.0 8.50mm
5.0 1.68mm
So by this trend, I need to set the Pulse unit to a number less than 0.01 to get the full 10mm at 2500 steps/rev resolution. The ideal case would be for me to run over 5000 steps/rev in order to keep the movement nice and smooth.
What am I missing? What am I doing wrong? Does the pulse unit work differently than I have assumed?
I do not have my laser tube installed (or ordered yet for that matter) so I am not sure if this is happening with my x or y axis as well. They appear to be moving the correct amount. I do not have the power/ synchronization problem with these axis as the are just normal Nema17 steppers on single drivers.
0.01 8.39mm
0.05 8.39mm
0.1 8.40mm
0.5 8.46mm
1.0 8.50mm
5.0 1.68mm
