EPS-LM2575-12V Voltage Regulator
Posted: Thu May 27, 2010 8:06 am
When I look at the unit -
The wire colors from Left to Right is: Orange, Black, Green, Black
Above the plug on the circuit board, is the following:
INDC-60V DC12V
If I assign pin numbers from left to right, 1-4,
Is correct wiring?
Pin 1 - Positive Input Voltage
Pin 2 - Negative Input Voltage
Pin 3 - Negative Output Voltage
Pin 4 - Positive Output Voltage
If so, I would think that the wires on Pins 3 and 4 would both be black.
Is there a hookup diagram somewhere?
INDC-60V DC12V
Is correct wiring?
